klausn's avatar
klausn
Tutor
Jan 26, 2017
Antivirus scanner how to manage after upgrading to 6.6.1
Hi,
Does anyone know what the next problem is?
After upgrading to Firmware 6.6.1 I can't manage the Antivirus scanner.
Before upgrading I could change the frequences of updating the Antivirus scanner.
Does anyone have an idea?
Please be kind and share with me.
Remarks: the antivirus program is still runnig on background and the led on the main screen (Admin Page) is green!
  • klausn's avatar
    klausn
    Jan 27, 2017
    Hi great you give me the link...... many txs
  • Retired_Member's avatar
    Retired_Member
    Any updates on the 6.6.1 firmware and AV issues?
  • The way to use the built in anti vrus is for me a bit blury and hard to understand too!
    For me I turned it on, then the unit downloaded the app, then it updated the virus files and then it went green and a shield appeared on the unit.
    • StephenB's avatar
      For right now the only controls are "on" and "off".
      I think that's a huge problem, hopefully there will be more options soon.
      • klausn's avatar
        klausn
        Tutor
        Hi,
        I read a lot and could not find anything about it.
        The programm is still running and updating, but managing or seen in my App isn't possible.
        The Antivisus App is disappeared............
        :smileysurprised:
ProSupport for Business
