hswope
Apr 22, 2017Aspirant
Authenticating ReadyNAS with FreeIPA
I am debating the purchase of a ReadyNAS device and want to no if it can use FreeIPA for authentication in general and specifically for CIFS shares. ???
hswope
Apr 23, 2017Aspirant
I have had limitted success using FreeIPA in places where AD would be used. Windows clients can use it to access shared resources, but they couldn't join it as if it where an AD domain for example. I have had good success using it in places where LDAP is used as it combines LDAP and kerberos and other services to perform its directory service functions.
Does ReadyNAS have any LDAP support? Actually there is a FreeIPA client for debian. I believe ReadyNAS is based off of debian linux. Would it blow the NAS software out of the water if it were made a FreeIPA client?
Apr 24, 2017Guru - Experienced User
hswope wrote:
...Would it blow the NAS software out of the water if it were made a FreeIPA client?
I really don't know - I'd always assumed that the ReadyNAS was using LDAP - but my knowledge about AD is limited, and I have no idea how the AD integration in the NAS software is implemented.
Hopefully someone from Netgear development will chime in.
- hswopeApr 24, 2017Aspirant
Thanks for your input...
I think I read somewhere there was a way to run ReadyNAS in a VM. Maybe I can fire up one of those and do some testing.
- StephenBApr 24, 2017Guru - Experienced User
This might help get you started: https://github.com/ReadyNAS/sdk/wiki/Setup-ReadyNAS-OS-on-VirtualBox
Let us know what you find out.
Also, you might post FreeIPA support as a suggestion on the Idea Exchange here: https://community.netgear.com/t5/Idea-Exchange-for-ReadyNAS/idb-p/idea-exchange-for-storage?topic-zoom=&sort-by=&date-range=all
Perfect... Thanks. I will give it a try.
