MichaelR64
May 24, 2016Aspirant
Can my 4.2.2x (Ultra 6) disks be accessible on a OS6 system ?
Hi,
My Ultra 6 (4.2.2x) died on me yesterday. It won't go past the bootlogo. Also the procedure with going into the bootmenu doesn't work with or without the disks.
The disks were ok before this happened so i called Netgear support NL.
They assured me that i could just pop these disks in a OS6 system(ofcourse in the same order) like a 316 and they would be accessible again.
Although some functions wouldn't be available the shares would be accesible.
I could then backup this to another NAS and , reset and factory reset the new unit and then put the data back again.
Could someone confirm this and explain how and what happens when i do this ?
Offcourse i am a little anxious that the unit would start formatting these unknown and 'old' disks.
Does it matter that OS6 uses btrfs and the 4.2.2x ?
I got my hands on a Pro 6 with OS6.5 on it, factory defaulted and all. Does this change anything or matter here ?
I hope somebody has some answers for me.
rgrds Mike
- JennCNETGEAR Employee Retired
Hello MichaelR64,
You might want to look at ReadyNAS: Migrating disks from RAIDiator 4.2 to ReadyNAS OS 6 (x86) article.
Hope this helps.
- MichaelR64Aspirant
Ok,
So i took the plunge and installed the disks in the other (working) Pro 6 system.
It boots and even displays frontview.
However it notes the volume as being offline.
All disks are being seen as fine, as i had expected since i had no problems with these in the first place.
I logged in tru ssh and ran fdisk -l to get some more info. (I found this somewhere else n the forum).
(I noticed something else: the previous owner claimed he had upgraded the unti to OS6.5 but since the os runs from the disk my setup offcourse shows 4.2.26.)
Also the display on the unit keeps displaying 'Booting' .
Does anybody now why the volume is offline and how can i get it online ?
Is this behaviour also to be expected when i put these disks in a new 316 ?
If not i could just go out and buy a 316 if that solves it.
I have already bought some big usb drives because support told me that the volume would get online but in some kind of readonly mode.
(So i could offload the data to a usb drive and do a factory reset).
I have logs downloaded as well, if anyone is interested.
Output is posted below.
nas-EB-0B-D5:~# fdisk -l fdisk: device has more than 2^32 sectors, can't use all of them Found valid GPT with protective MBR; using GPT Disk /dev/sda: 4294967295 sectors, 2047G Logical sector size: 512 Disk identifier (GUID): 6ef40563-79ef-4d6a-a469-243cea1e8141 Partition table holds up to 128 entries First usable sector is 34, last usable sector is 5860533134 Number Start (sector) End (sector) Size Code Name 1 64 8388671 4096M 0700 2 8388672 9437247 512M 0700 3 9437248 5860529072 2790G 0700 fdisk: device has more than 2^32 sectors, can't use all of them Found valid GPT with protective MBR; using GPT Disk /dev/sdb: 4294967295 sectors, 2047G Logical sector size: 512 Disk identifier (GUID): 3769a122-b786-4452-8a59-35078f0be5ca Partition table holds up to 128 entries First usable sector is 34, last usable sector is 5860533134 Number Start (sector) End (sector) Size Code Name 1 64 8388671 4096M 0700 2 8388672 9437247 512M 0700 3 9437248 5860529072 2790G 0700 fdisk: device has more than 2^32 sectors, can't use all of them Found valid GPT with protective MBR; using GPT Disk /dev/sdc: 4294967295 sectors, 2047G Logical sector size: 512 Disk identifier (GUID): fc68665e-f386-4bb2-a4bc-76a5e03c6f4e Partition table holds up to 128 entries First usable sector is 34, last usable sector is 5860533134 Number Start (sector) End (sector) Size Code Name 1 64 8388671 4096M 0700 2 8388672 9437247 512M 0700 3 9437248 5860529072 2790G 0700 fdisk: device has more than 2^32 sectors, can't use all of them Found valid GPT with protective MBR; using GPT Disk /dev/sdd: 4294967295 sectors, 2047G Logical sector size: 512 Disk identifier (GUID): b53142a5-e367-4807-8eb5-9c44396bdb70 Partition table holds up to 128 entries First usable sector is 34, last usable sector is 5860533134 Number Start (sector) End (sector) Size Code Name 1 64 8388671 4096M 0700 2 8388672 9437247 512M 0700 3 9437248 5860529072 2790G 0700 fdisk: device has more than 2^32 sectors, can't use all of them Found valid GPT with protective MBR; using GPT Disk /dev/sde: 4294967295 sectors, 2047G Logical sector size: 512 Disk identifier (GUID): 622c9f83-44c7-45bf-9082-ba75ce428b73 Partition table holds up to 128 entries First usable sector is 34, last usable sector is 5860533134 Number Start (sector) End (sector) Size Code Name 1 64 8388671 4096M 0700 2 8388672 9437247 512M 0700 3 9437248 5860529072 2790G 0700 fdisk: device has more than 2^32 sectors, can't use all of them Found valid GPT with protective MBR; using GPT Disk /dev/sdf: 4294967295 sectors, 2047G Logical sector size: 512 Disk identifier (GUID): 358e1235-489c-4db1-ada2-c473f8f03925 Partition table holds up to 128 entries First usable sector is 34, last usable sector is 5860533134 Number Start (sector) End (sector) Size Code Name 1 64 8388671 4096M 0700 2 8388672 9437247 512M 0700 3 9437248 5860529072 2790G 0700 Disk /dev/md0: 4293 MB, 4293906432 bytes 2 heads, 4 sectors/track, 1048317 cylinders Units = cylinders of 8 * 512 = 4096 bytes Disk /dev/md0 doesn't contain a valid partition table fdisk: device has more than 2^32 sectors, can't use all of them Disk /dev/dm-0: 2199.0 GB, 2199023255040 bytes 255 heads, 63 sectors/track, 267349 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Disk /dev/dm-0 doesn't contain a valid partition table
volume log:
===== pvscan ===== PV /dev/md2 VG c lvm2 [13.62 TB / 10.00 GB free] Total: 1 [1.62 TB] / in use: 1 [1.62 TB] / in no VG: 0 [0 ] ===== vgscan ===== Reading all physical volumes. This may take a while... Found volume group "c" using metadata type lvm2 ===== lvscan ===== ACTIVE '/dev/c/c' [13.61 TB] inherit ===== vgdisplay ===== --- Volume group --- VG Name c System ID Format lvm2 Metadata Areas 1 Metadata Sequence No 7 VG Access read/write VG Status resizable MAX LV 0 Cur LV 1 Open LV 0 Max PV 0 Cur PV 1 Act PV 1 VG Size 13.62 TB PE Size 64.00 MB Total PE 223201 Alloc PE / Size 223041 / 13.61 TB Free PE / Size 160 / 10.00 GB VG UUID DTkKdS-BNwO-fUyz-jen7-e5GV-DqZH-eN91py ===== lvdisplay /dev/c/c ===== --- Logical volume --- LV Name /dev/c/c VG Name c LV UUID 7rRXpm-r4zh-RUlD-DgKw-AHDU-8iIe-RRe7W5 LV Write Access read/write LV Status available # open 0 LV Size 13.61 TB Current LE 223041 Segments 1 Allocation inherit Read ahead sectors 0 Block device 251:0 ===== dumpe2fs /dev/c/c ===== dumpe2fs 1.42.8 (20-Jun-2013) Filesystem volume name: <none> Last mounted on: /c Filesystem UUID: 121e0cd1-f544-401b-896c-31df123da04f Filesystem magic number: 0xEF53 Filesystem revision #: 1 (dynamic) Filesystem features: has_journal ext_attr resize_inode dir_index filetype extent 64bit flex_bg sparse_super large_file huge_file uninit_bg dir_nlink extra_isize Filesystem flags: signed_directory_hash Default mount options: user_xattr acl Filesystem state: clean Errors behavior: Remount read-only Filesystem OS type: Linux Inode count: 228395008 Block count: 3654303744 Reserved block count: 12500000 Free blocks: 813475891 Free inodes: 227843032 First block: 0 Block size: 4096 Fragment size: 4096 Reserved GDT blocks: 305 Blocks per group: 32768 Fragments per group: 32768 Inodes per group: 2048 Inode blocks per group: 128 RAID stride: 16 RAID stripe width: 80 Flex block group size: 16 Filesystem created: Thu Aug 16 22:55:04 2012 Last mount time: Sat Aug 15 06:15:22 2015 Last write time: Sat May 28 11:42:11 2016 Mount count: 22 Maximum mount count: -1 Last checked: Thu Aug 16 22:55:04 2012 Check interval: 0 (<none>) Lifetime writes: 49 TB Reserved blocks uid: 0 (user unknown) Reserved blocks gid: 0 (group unknown) First inode: 11 Inode size: 256 Required extra isize: 28 Desired extra isize: 28 Journal inode: 8 Default directory hash: half_md4 Directory Hash Seed: 821b1544-bad0-432e-b613-f03d086917cc Journal backup: inode blocks Journal features: journal_incompat_revoke Journal size: 128M Journal length: 32768 Journal sequence: 0x00a509eb Journal start: 0 ===== fstab ===== #----------------------------------------------------------------------------- # <device> <mount> <type> <options> <freq> <pass> #----------------------------------------------------------------------------- /dev/md0 / ext3 defaults,noatime,nodiratime 0 0 proc /proc proc defaults 0 0 /dev/md1 swap swap defaults 0 0 /dev/c/c /c ext4 defaults,acl,user_xattr,usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv1,noatime,nodiratime 0 2
partition log:
***** partition output for sda ***** Disk /dev/sda: 5860533168 sectors, 2.7 TiB Logical sector size: 512 bytes Disk identifier (GUID): 6EF40563-79EF-4D6A-A469-243CEA1E8141 Partition table holds up to 128 entries First usable sector is 34, last usable sector is 5860533134 Partitions will be aligned on 64-sector boundaries Total free space is 4092 sectors (2.0 MiB) Number Start (sector) End (sector) Size Code Name 1 64 8388671 4.0 GiB FD00 2 8388672 9437247 512.0 MiB FD00 3 9437248 5860529072 2.7 TiB FD00 Disk /dev/sda: 364801 cylinders, 255 heads, 63 sectors/track Units = cylinders of 8257536 bytes, blocks of 1024 bytes, counting from 0 Device Boot Start End #cyls #blocks Id System /dev/sda1 0+ - 0- 2147483647+ ee EFI GPT /dev/sda2 0 - 0 0 0 Empty /dev/sda3 0 - 0 0 0 Empty /dev/sda4 0 - 0 0 0 Empty ***** partition output for sdb ***** Disk /dev/sdb: 5860533168 sectors, 2.7 TiB Logical sector size: 512 bytes Disk identifier (GUID): 3769A122-B786-4452-8A59-35078F0BE5CA Partition table holds up to 128 entries First usable sector is 34, last usable sector is 5860533134 Partitions will be aligned on 64-sector boundaries Total free space is 4092 sectors (2.0 MiB) Number Start (sector) End (sector) Size Code Name 1 64 8388671 4.0 GiB FD00 2 8388672 9437247 512.0 MiB FD00 3 9437248 5860529072 2.7 TiB FD00 Disk /dev/sdb: 364801 cylinders, 255 heads, 63 sectors/track Units = cylinders of 8257536 bytes, blocks of 1024 bytes, counting from 0 Device Boot Start End #cyls #blocks Id System /dev/sdb1 0+ - 0- 2147483647+ ee EFI GPT /dev/sdb2 0 - 0 0 0 Empty /dev/sdb3 0 - 0 0 0 Empty /dev/sdb4 0 - 0 0 0 Empty ***** partition output for sdc ***** Disk /dev/sdc: 5860533168 sectors, 2.7 TiB Logical sector size: 512 bytes Disk identifier (GUID): FC68665E-F386-4BB2-A4BC-76A5E03C6F4E Partition table holds up to 128 entries First usable sector is 34, last usable sector is 5860533134 Partitions will be aligned on 64-sector boundaries Total free space is 4092 sectors (2.0 MiB) Number Start (sector) End (sector) Size Code Name 1 64 8388671 4.0 GiB FD00 2 8388672 9437247 512.0 MiB FD00 3 9437248 5860529072 2.7 TiB FD00 Disk /dev/sdc: 364801 cylinders, 255 heads, 63 sectors/track Units = cylinders of 8257536 bytes, blocks of 1024 bytes, counting from 0 Device Boot Start End #cyls #blocks Id System /dev/sdc1 0+ - 0- 2147483647+ ee EFI GPT /dev/sdc2 0 - 0 0 0 Empty /dev/sdc3 0 - 0 0 0 Empty /dev/sdc4 0 - 0 0 0 Empty ***** partition output for sdd ***** Disk /dev/sdd: 5860533168 sectors, 2.7 TiB Logical sector size: 512 bytes Disk identifier (GUID): B53142A5-E367-4807-8EB5-9C44396BDB70 Partition table holds up to 128 entries First usable sector is 34, last usable sector is 5860533134 Partitions will be aligned on 64-sector boundaries Total free space is 4092 sectors (2.0 MiB) Number Start (sector) End (sector) Size Code Name 1 64 8388671 4.0 GiB FD00 2 8388672 9437247 512.0 MiB FD00 3 9437248 5860529072 2.7 TiB FD00 Disk /dev/sdd: 364801 cylinders, 255 heads, 63 sectors/track Units = cylinders of 8257536 bytes, blocks of 1024 bytes, counting from 0 Device Boot Start End #cyls #blocks Id System /dev/sdd1 0+ - 0- 2147483647+ ee EFI GPT /dev/sdd2 0 - 0 0 0 Empty /dev/sdd3 0 - 0 0 0 Empty /dev/sdd4 0 - 0 0 0 Empty ***** partition output for sde ***** Disk /dev/sde: 5860533168 sectors, 2.7 TiB Logical sector size: 512 bytes Disk identifier (GUID): 622C9F83-44C7-45BF-9082-BA75CE428B73 Partition table holds up to 128 entries First usable sector is 34, last usable sector is 5860533134 Partitions will be aligned on 64-sector boundaries Total free space is 4092 sectors (2.0 MiB) Number Start (sector) End (sector) Size Code Name 1 64 8388671 4.0 GiB FD00 2 8388672 9437247 512.0 MiB FD00 3 9437248 5860529072 2.7 TiB FD00 Disk /dev/sde: 364801 cylinders, 255 heads, 63 sectors/track Units = cylinders of 8257536 bytes, blocks of 1024 bytes, counting from 0 Device Boot Start End #cyls #blocks Id System /dev/sde1 0+ - 0- 2147483647+ ee EFI GPT /dev/sde2 0 - 0 0 0 Empty /dev/sde3 0 - 0 0 0 Empty /dev/sde4 0 - 0 0 0 Empty ***** partition output for sdf ***** Disk /dev/sdf: 5860533168 sectors, 2.7 TiB Logical sector size: 512 bytes Disk identifier (GUID): 358E1235-489C-4DB1-ADA2-C473F8F03925 Partition table holds up to 128 entries First usable sector is 34, last usable sector is 5860533134 Partitions will be aligned on 64-sector boundaries Total free space is 4092 sectors (2.0 MiB) Number Start (sector) End (sector) Size Code Name 1 64 8388671 4.0 GiB FD00 2 8388672 9437247 512.0 MiB FD00 3 9437248 5860529072 2.7 TiB FD00 Disk /dev/sdf: 364801 cylinders, 255 heads, 63 sectors/track Units = cylinders of 8257536 bytes, blocks of 1024 bytes, counting from 0 Device Boot Start End #cyls #blocks Id System /dev/sdf1 0+ - 0- 2147483647+ ee EFI GPT /dev/sdf2 0 - 0 0 0 Empty /dev/sdf3 0 - 0 0 0 Empty /dev/sdf4 0 - 0 0 0 Empty
mdstat:
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] md2 : active raid5 sda3[0] sdf3[5] sde3[4] sdd3[3] sdc3[2] sdb3[1] 14627723520 blocks super 1.2 level 5, 64k chunk, algorithm 2 [6/6] [UUUUUU] md1 : active raid6 sda2[0] sdf2[5] sde2[4] sdd2[3] sdc2[2] sdb2[1] 2096896 blocks super 1.2 level 6, 64k chunk, algorithm 2 [6/6] [UUUUUU] md0 : active raid1 sda1[0] sdf1[5] sde1[4] sdd1[3] sdc1[2] sdb1[1] 4193268 blocks super 1.2 [6/6] [UUUUUU] unused devices: <none>disk-usage:
Filesystem Size Used Avail Use% Mounted on /dev/md0 4.0G 574M 3.2G 16% / tmpfs 16K 0 16K 0% /USB
raid.conf:
/dev/md0,root!!number=0,chan=0,dev=/dev/sda1,model=WDC WD30EFRX-68AX9N0,sectors=5860533168,raid_disk=0!!number=1,chan=1,dev=/dev/sdb1,model=WDC WD30EFRX-68AX9N0,sectors=5860533168,raid_disk=1!!number=2,chan=2,dev=/dev/sdc1,model=WDC WD30EFRX-68AX9N0,sectors=5860533168,raid_disk=2!!number=3,chan=3,dev=/dev/sdd1,model=WDC WD30EFRX-68AX9N0,sectors=5860533168,raid_disk=3!!number=4,chan=4,dev=/dev/sde1,model=WDC WD30EFRX-68EUZN0,sectors=5860533168,raid_disk=4!!number=5,chan=5,dev=/dev/sdf1,model=WDC WD30EFRX-68EUZN0,sectors=5860533168,raid_disk=5 /dev/md1,swap!!number=0,chan=0,dev=/dev/sda2,model=WDC WD30EFRX-68AX9N0,sectors=5860533168,raid_disk=0!!number=1,chan=1,dev=/dev/sdb2,model=WDC WD30EFRX-68AX9N0,sectors=5860533168,raid_disk=1!!number=2,chan=2,dev=/dev/sdc2,model=WDC WD30EFRX-68AX9N0,sectors=5860533168,raid_disk=2!!number=3,chan=3,dev=/dev/sdd2,model=WDC WD30EFRX-68AX9N0,sectors=5860533168,raid_disk=3!!number=4,chan=4,dev=/dev/sde2,model=WDC WD30EFRX-68EUZN0,sectors=5860533168,raid_disk=4!!number=5,chan=5,dev=/dev/sdf2,model=WDC WD30EFRX-68EUZN0,sectors=5860533168,raid_disk=5 /dev/md2,C!!number=0,chan=0,dev=/dev/sda3,model=WDC WD30EFRX-68AX9N0,sectors=5860533168,raid_disk=0!!number=1,chan=1,dev=/dev/sdb3,model=WDC WD30EFRX-68AX9N0,sectors=5860533168,raid_disk=1!!number=2,chan=2,dev=/dev/sdc3,model=WDC WD30EFRX-68AX9N0,sectors=5860533168,raid_disk=2!!number=3,chan=3,dev=/dev/sdd3,model=WDC WD30EFRX-68AX9N0,sectors=5860533168,raid_disk=3!!number=4,chan=4,dev=/dev/sde3,model=WDC WD30EFRX-68EUZN0,sectors=5860533168,raid_disk=4!!number=5,chan=5,dev=/dev/sdf3,model=WDC WD30EFRX-68EUZN0,sectors=5860533168,raid_disk=5
- mdgm-ntgrNETGEAR Employee Retired
Can you send in your logs (see the Sending Logs link in my sig)?
