Chickweed
Jul 08, 2015Aspirant
Can't access Duo admin
My Duo has been doing its job for a couple of years now as once I set it up, I haven't touched it. I recently replace the PCs in my house and have been pleased to find that the new Windows 8 machines...
Jul 08, 2015Guru - Experienced User
I think you are downloading the wrong thing (perhaps confusing RAIDator with RAIDar).
RAIDar 6.0 is here: https://readycloud.netgear.com/client/i ... RAIDar.exe
RAIDar 4.3.8 is here: http://www.downloads.netgear.com/files/ ... _4_3_8.exe
RAIDar 6.0 is nicer, but some setup functions don't work with the duo v1 - so you might want 4.3.8 (or maybe both). Neither download as zip files.
Normally you manage the duo directly from it's admin web page ("Frontview"). (https://duo.ip.address/admin). The default password for admin for your duo is netgear1.
If you don't remember the password, you will need to do an OS reinstall. Instructions for that are on page 16 of the hardware manual here: http://www.readynas.com/download/docume ... 6Dec11.pdf
The OS reinstall preserves your data and almost all settings. The admin password is reset to "netgear1" and the IP address is reset to use DHCP (automatic assignment). Though it is pretty safe, it is always wise to have an up-to-date backup...
