mgf's avatar
mgf
Can't access web interface since firmware 6.4
ReadyNas 102
Firmware 6.4 updated through web interface.
When I turn on the device the power light has a slow flash and this never stops.
After this I can no longer access the web interface
I can ping the IP address successfullly but when I try to connect I get 'Connection Refused'
I've tried reinstalling the firmware from a boot USB.  I've tried rolling back to 6.2.5 but same results regardless.
Readycloud says the device is Offline
Any suggestions would be welcome
      • Hi mgf,
        I have the same issue but the link to your solution is dead. Are you able to point me in the right direction?
        Thanks in advance for any help
