masa2
May 24, 2012Tutor
Connecting ReadyNAS Duo from Internet
Hello. I'm setting up my ReadyNAS Duo drive to my LAN and would like to be able to connect it from everywhere I want. Is it possible to do it any other way than installing ReadyNAS Remote applic...
May 24, 2012Guru - Experienced User
The answer to this depends on whether you have a v1 or a v2 duo. What firmware are you running?
