masa2
May 24, 2012Tutor
Connecting ReadyNAS Duo from Internet
Hello. I'm setting up my ReadyNAS Duo drive to my LAN and would like to be able to connect it from everywhere I want. Is it possible to do it any other way than installing ReadyNAS Remote applic...
May 28, 2012Guru - Experienced User
Does it connect from inside if you use the same URL?
Also, did you remember to enable http/s for the shares you want to access?
