mikebzh44
Oct 10, 2014Aspirant
Copy / Backup between NAS
Hi. I actually own a ReadyNAS Duo with 2 X 2 tb in RAID1 (mirror). My brother have justa bought a D-Link DNS-320L with 2 x 1.5 Tb in RAID1 and he want to get some of my files / folders (about 75...
mdgm-ntgr
Oct 10, 2014NETGEAR Employee Retired
1. If the DLink supports Rsync and has that enabled for the destination share you could run a backup job using Rsync on the ReadyNAS. If not you may need to try e.g. the Windows/NAS (Timestamp) backup option
2. The RAID format in the 102 is different so you should put new disks in the 102 and copy your data across your network. I would suggest enabling Rsync for your shares on the Duo and running backup jobs on the 102, with the Remote Rsync Server (Duo) as the source and the share you want to backup to on the 102 as the destination
