codegrinder
Nov 30, 2006Aspirant
Drives "locked" after being in NV. HELP!!!
i was doing some trouble shooting with my nv and swaped my seagate disks out for 4 wd raptor drives and they worked fine in a raid 0 setup. after i was done testing i stuck them back in my desktop and...
c3po
Dec 01, 2006NETGEAR Expert
codegrinder wrote: this worked. thanks. i wasn't able to use the passwords you provided with the unlock command via the mhdd hard drive disk. but doing the xraid and expanding them worked well, the password(s) are gone.
Thanks for update. Although the chance of hitting this problem is very
low, we will make sure that a disk can be used in PC if it can be used
in ReadyNAS in future release(i.e. Guarantee the same problem will not
happen)
