Monteverde's avatar
Monteverde
Duo v1 hangs during sync and losses network
Hi,
I have a ReadyNas Duo v1 with two 2 TB disks  in RAID configuration (don't remember which), The 2TB disk space is almost full, ~95%.
Maximum memory.
I also have a UPS connected to the NAS. Mostly video and music files.
The NAS has the latest RAIDiator release and has been working fine for several years. Disk upgrade some years ago.
Problem description:
I suddenly noticed that I didn't have access to the NAS anymore using web interface, nor ping responding to pings.
Both disk LEDs are green. The activity LED blinks now and then (10 -15 s between blinks). Power button LED is blue.
I have ssh activated.
I can't turn off the NAS using the power button, non responsive to short or long pressing.
Obviously I can't log in with ssh, due to no network connection.
I pulled the power cord and waited a while and then turned it on agin.
The NAS start syncing the disks. I can see that this happens in RAIDar.
I can ping it during the sync and log in with ssh.
When the sync has reached about 77% it loses network connection and becomes non responsive agin, as above.
I have mounted the disks on Windows PC and backed up what could be read out from disk 1, disk 2 seems not to have any paritions.
Most file on disk 1 seems to ok. Some directories that should contain file are empy, some has a file(name) but I can't recover a file.
Questions:
Q1: Any idea why sync stops and NAS gets unresponsive?
Q2: How can I determince which RAID type I am usnig by looking at some file when logging in with SSH?
Q3: Any specific log file I should  look in (filename and path plese)?
Q4: Should disk 2 be without any parition, seem strange to me (parity disk?)?
Q5. Any idea how to recover files?
Q6; Should I have frontview access during sync?
Thanks in advance!
  • StephenB's avatar
    Disk 2 has an OS partition but no data partition.  Data is mirrored there none the less.
    It sounds like you must have RAID-1, but that could be either xraid or flexraid.  What tool did you use to extract the data on the PC?  With xraid, I suggest linux reader ( http://www.diskinternals.com/linux-reader/ )
    When you can access via ssh, did you check OS partition fullness?
    df . -h
    df . -i
    Note you can also remove disk 2 and boot the NAS w/o it.  Then it can't sync.  It might still lock up.
    Be careful not to insert a disk with the NAS running right now though - it will format it, and that is not what you want.
    • Monteverde's avatar
      Monteverde
      Hi,
      Yes, I used the linux-reader tool from diskinternals.com as recommmend in other threads in this forum.
      I definitly think I use X-RAID and not Flex-RAID.
      Removed disk2 when nas was down and start up. Logged in with ssh and checked the proposed commands, see below:
      Filesystem            Size  Used Avail Use% Mounted on
      /dev/hdc1             1.9G  608M  1.3G  31% /
      nas-76-26-27:/# df . -i
      Filesystem            Inodes   IUsed   IFree IUse% Mounted on
      /dev/hdc1             128000   12157  115843   10% /
      Should I have had disk2 inserted?
      I only find the following log files updated in the system, see below. Shouldn't other logfiles have updates?
      nas-76-26-27:/# cat /var/log/frontview/memory.log
      SZ: 1024
      AT: 2.5-3-3-7
      PN: 4b0000000000000000000000000000000000
      RV: 0000
      DT: 0921
      SN: a1147869
      nas-76-26-27:/# cat /var/log/frontview/enclosure.log
      fan!!1!!status=ok::descr=1744RPM
      ups!!1!!status=fail::descr=APC Back-UPS CS 350 Battery charge: 100%, 77 min
      volume!!1!!status=ok::descr=Volume C: RAID Level X, Redundant; 1751 GB (94%) of 1853 GB used
      disk!!1!!status=ok::descr=Channel 1: SAMSUNG HD204UI 1863 GB, 34C/93F
      disk!!2!!status=ok::descr=Channel 2: SAMSUNG HD204UI 1863 GB, 31C/87F
      model!!0!!mode=home::descr=ReadyNAS Duo::arch=nsp
      Boot!!FS_CHECK!! 53%
      nas-76-26-27:/# cat /tmp/fsck.log ***** File system check performed at Fri Jan 29 23:57:15 CET 2016 ***** fsck 1.40.11 (17-June-2008) e2fsck 1.40.11 (17-June-2008) c was not cleanly unmounted, check forced. Pass 1: Checking inodes, blocks, and sizes
      It locked again at ~70% into the file checking
      I ran the  top command just to see if there were any resources were low, but I don't think it looks strange
      Any ideas?
      • StephenB's avatar
        Your OS partition is fine. You must be using xraid, because linux reader wouldn't see the files if you were using flexraid.
        I think you have a corrupt file system (and that the lockup is in fsck, not raid resync).  Though I can't rule out a failing disk.
        You could shut down, and insert disk 2 alone (in the second slot) and see if you get the same behavior.  My guess is that you will, but it is worth a try.
        It is also worth testing the disks with vendor diags in a PC (seatools for seagate, lifeguard for western digital).
        Assuming the lockup happens with only disk 2 installed, the options are to
        (a) attempt to repair the file system yourself
        (b) contract with Netgear for data recovery
        (c) accept the data loss - do a factory reset on the NAS, reconfigure it, and restore the data from a backup.
        No matter what option you pick, create a backup on your PC first -  using linux reader (copying the files linux reader sees to a USB disk or an NTFS internal disk).
ProSupport for Business
