glem
May 22, 2013Aspirant
Easy fix fan/temp OS6 issues on x86 legacy #no support
>> EDIT - 2014-04-12 <<
Before to hack your system, update first to 6.1.7. Built-in fancontrol support is there!
6.1.7 has been released: http://www.readynas.com/forum/viewtopic.php?f=1&t=76000
>> EDIT <<
Here is how to fix fan and temperature issues on legacy x86 systems running OS 6.x, until built-in support is there.
I'd previously created this post http://www.readynas.com/forum/viewtopic.php?f=51&t=70133&start=255#p393886 but it will be easier for community to have fancontrol file examples for all models in a dedicated post.
It's a very easy and reliable method to monitor fan and temperature with lm-sensors and fancontrol standard packages.
No change on GUI reports.
NO WARRANTY / NO SUPPORT !!!
with root access, execute the following commands:
edit /etc/fancontrol file and copy the following file example corresponding to your model http://www.readynas.com/forum/viewtopic.php?f=51&t=71155#p395324
or create your own /etc/fancontrol file using pwmconfig command http://www.readynas.com/forum/viewtopic.php?f=51&t=71155&p=395324#p395318
fancontrol daemon start automaticaly when you install it.
restart fancontrol daemon for changes in file /etc/fancontrol take effect
to interact with fancontrol daemon, use
You can display sensors values with sensors command
>> EDIT <<
apt-get update && apt-get upgrade
apt-get install lm-sensors fancontrol
echo "#fancontrol" > /etc/fancontrol
/etc/init.d/fancontrol restart
/etc/init.d/fancontrol stop
/etc/init.d/fancontrol start
root@nas-xx-xx-xx:~# sensors
coretemp-isa-0000
Adapter: ISA adapter
Core 0: +43.0°C (high = +80.0°C, crit = +100.0°C)
Core 1: +49.0°C (high = +80.0°C, crit = +100.0°C)
it8721-isa-0a10
in0: +12.19 V (min = +8.06 V, max = +10.66 V) ALARM
in1: +4.98 V (min = +2.20 V, max = +3.51 V) ALARM
in2: +3.28 V (min = +0.02 V, max = +0.18 V) ALARM
in3: +0.00 V (min = +0.00 V, max = +0.00 V) ALARM
in4: +1.02 V (min = +1.42 V, max = +2.21 V) ALARM
in5: +1.80 V (min = +1.66 V, max = +0.54 V) ALARM
in6: -12.10 V (min = -25.78 V, max = -0.01 V)
in7: +3.24 V (min = +0.00 V, max = +2.86 V) ALARM
in8: +3.34 V
fan1: 0 RPM (min = 10 RPM) ALARM
fan2: 0 RPM (min = 44 RPM) ALARM
fan3: 851 RPM (min = 11 RPM)
temp1: +0.0°C (low = +57.0°C, high = -25.0°C) ALARM sensor = thermistor
temp2: +0.1°C (low = -16.0°C, high = -123.0°C) ALARM sensor = thermal diode
temp3: +0.1°C (low = +37.0°C, high = -44.0°C) ALARM sensor = thermal diode
cpu0_vid: +2.050 V
- masammutAspirantGlem,
I have the old version rndp6350 - will you guide me on what file I need to add in sensors.d? I suppose the ultra version is different to mine as adding the file did nothing. I even renamed it to rndp6000.conf.
Also do I need to refer to this file from anywhere else?
I have latest 6.1.4.
Sorry to be such a noob, but where do I find the name of my chip? The folder with teh fan and temps is w83627ehf.2576 on mine.
I also noticed that the temperature graph is blank.
Cheers - moseleypjAspirant
ATCIS wrote: In case anyone cares. . . I finally got the graph working!
As it turns out it was likely a permissions problem ALL ALONG :oops:
Still something not quite right though. I just checked the ambient room temperature which is approximately 82 degrees F. How can the CPU temperature be 79 degrees F? As I watch the graph over time both temperatures are dropping slightly every minute. The System temperature seems reasonable. It is currently 97 degrees F. I'll keep an eye on things for a while and report back later. . .
I've been trying to get the graphs I've generated embedded in the performance tab but can't see which file it's rendered from. How did you manage to do it? :shock: - ATCISTutor
moseleypj wrote: I've been trying to get the graphs I've generated embedded in the performance tab but can't see which file it's rendered from. How did you manage to do it?
Perhaps we could give you a bit of guidance if you shared with us the platform you are trying to get this working on? - renedisAspirantCan someone help me out please?
My frontview temp readings are not OK.
My fans work fine but are not showing up correct in frontview.
output of the sensors are:coretemp-isa-0000
Core 0: +44.0°C (high = +84.0°C, crit = +100.0°C)
Core 1: +46.0°C (high = +84.0°C, crit = +100.0°C)
Core 2: +42.0°C (high = +84.0°C, crit = +100.0°C)
Core 3: +42.0°C (high = +84.0°C, crit = +100.0°C)
w83627dhg-isa-0a10
Vcore: +1.14 V (min = +0.00 V, max = +1.74 V)
in1: +1.87 V (min = +0.54 V, max = +0.89 V) ALARM
AVCC: +3.22 V (min = +2.98 V, max = +3.63 V)
+3.3V: +3.20 V (min = +2.98 V, max = +3.63 V)
in4: +1.23 V (min = +1.14 V, max = +0.64 V) ALARM
in5: +1.49 V (min = +1.14 V, max = +1.18 V) ALARM
in6: +1.02 V (min = +1.70 V, max = +1.66 V) ALARM
3VSB: +3.18 V (min = +2.98 V, max = +3.63 V)
Vbat: +3.12 V (min = +2.70 V, max = +3.63 V)
fan1: 1222 RPM (min = 28125 RPM, div = 16) ALARM
fan2: 1814 RPM (min = 1467 RPM, div = 8)
fan3: 1132 RPM (min = 733 RPM, div = 8)
fan4: 0 RPM (min = 2109 RPM, div = 128) ALARM
fan5: 0 RPM (min = 878 RPM, div = 128) ALARM
temp1: +58.0°C (high = -1.0°C, hyst = +125.0°C) sensor = thermistor
temp2: +33.0°C (high = +80.0°C, hyst = +123.0°C) sensor = CPU diode
temp3: -47.0°C (high = +80.0°C, hyst = +123.0°C) sensor = thermistor
cpu0_vid: +0.000 V
And there is no file rndu6000.conf in etc/sensors.d/, only rn2120.conf with the following text:chip "g760a-i2c-*-3e"
label fan1 "fan1"
chip "g760a-i2c-*-48"
label fan1 "fan2"
chip "g760a-i2c-*-49"
label fan1 "fan3"
So i've added the line to that file:chip "it8721-isa-0a10"
compute fan1 0+fan3_input,0-fan3_input
compute temp2 0+temp1_input,0-temp1_input
Stil the same story.. I even added the file rndu6000.conf to the folder with the text above without any luck.
My fan control file is from the PRO6, al the other settings fail and cause my CPU fan to max out on RPM.# Configuration file generated by pwmconfig, changes will be lost
INTERVAL=10
DEVPATH=hwmon0=devices/platform/coretemp.0 hwmon1=devices/platform/w83627ehf.2576
DEVNAME=hwmon0=coretemp hwmon1=w83627dhg
FCTEMPS= hwmon1/device/pwm2=hwmon1/device/temp2_input hwmon1/device/pwm1=hwmon1/device/temp1_input
FCFANS= hwmon1/device/pwm2=hwmon1/device/fan2_input hwmon1/device/pwm1=hwmon1/device/fan1_input
MINTEMP= hwmon1/device/pwm2=30 hwmon1/device/pwm1=55
MAXTEMP= hwmon1/device/pwm2=60 hwmon1/device/pwm1=60
MINSTART= hwmon1/device/pwm2=70 hwmon1/device/pwm1=16
MINSTOP= hwmon1/device/pwm2=70 hwmon1/device/pwm1=16
MINPWM= hwmon1/device/pwm2=70 hwmon1/device/pwm1=16
MAXPWM= hwmon1/device/pwm2=200 hwmon1/device/pwm1=80
Any help would be great! - moseleypjAspirant
ATCIS wrote: moseleypj wrote: I've been trying to get the graphs I've generated embedded in the performance tab but can't see which file it's rendered from. How did you manage to do it?
I'm trying to get the graphs on a RN102 and RN104 with OS 6.1.5 - ATCISTutor
moseleypj wrote: I'm trying to get the graphs on a RN102 and RN104 with OS 6.1.5
Hmmm. . . I must be missing something here. I thought that both the RN102 and RN104 models shipped with OS6 out of the box. Shouldn't ALL the graphs and other graphical elements be working correctly without the need to perform any of the hacks that those of us who are running OS6 on legacy hardware? I'm confused. . . :-? - StephenBGuru - Experienced UserThe RN102/RN104 are OS6 only.
You can see the picture in the "performance" tab. However, the graphs are not available on the RN1xx. Per the manual:
I'm not sure why this limitation is there, but I wish it weren't.Note: Status graphics are not supported for ReadyNAS 102 and 104 systems. - moseleypjAspirantSo are all the graphs available on the higher models, or is it a hack to get them showing in all models?
- StephenBGuru - Experienced UserI know of no hack, and I think all the people who have shown the graphs are running the x86 OS6 binary (RN3xx/RN611/ultra/pro).
- moseleypjAspirantHmm, I wonder where the code that renders the front page is stored... If anyone has any info. I'd be very appreciative, else I'll have to look into it after my last exam!
