espakman
Oct 04, 2016Aspirant
Error while uploading with webdav after upgrading to 6.6.0
Hi, After upgrading to ReadyNAS 6.6.0 form 6.5.2 my webdav uploads don't work anymore. Just before the upgrade it still worked, but afterwards I get a "error uploading file!"
- Oct 18, 2016
You can apply a hot-fix for this issue, by downloading this package and installing it from the Apps tab, using the Upload button.
JennC
Oct 05, 2016NETGEAR Employee Retired
Hello espakman,
Did you already enable and disable WebDav and HTTP security of the share if that is set to Everyone? Please also check on the share that has WebDav enabled if there are any changes on the settings.
