espakman
Oct 04, 2016Aspirant
Error while uploading with webdav after upgrading to 6.6.0
Hi, After upgrading to ReadyNAS 6.6.0 form 6.5.2 my webdav uploads don't work anymore. Just before the upgrade it still worked, but afterwards I get a "error uploading file!"
- Oct 18, 2016
You can apply a hot-fix for this issue, by downloading this package and installing it from the Apps tab, using the Upload button.
espakman
Oct 05, 2016Aspirant
Hello JennC,
Yes I already tried that: disabling and enabling webdav and http on the share, rebooting and changing security from users to everyone and back. As far as I can see there are no changes in the settings. I can still connect with webdav and download files. But uploading isn't possible anymore. Right before the upgrade from 6.5.2 to 6.6.0 that part still worked.
Eric
JennC
Oct 05, 2016NETGEAR Employee Retired
Hello espakman,
Can you still copy files to the share via SMB?
