PillNAS
Sep 13, 2013Aspirant
Factory Reset Help
Hello, I'm new to this so please bear with me........I have been trying to update the firmware on my ReadyNAS Duo V2 from 5.3.7 to 5.3.8. I have tried to update it using the Dashboard but this did not...
vandermerwe
Sep 13, 2013Master
Yes I agree that all my suggestion may achieve is an OS reinstall after the disks are reinstalled.
I thought that since he's been advised to factory default the unit he could achieve this without destroying his data.
Would support not have suggested this because they thought there was a problem with the software on the device rather than the disks?
