PillNAS
Sep 13, 2013Aspirant
Factory Reset Help
Hello, I'm new to this so please bear with me........I have been trying to update the firmware on my ReadyNAS Duo V2 from 5.3.7 to 5.3.8. I have tried to update it using the Dashboard but this did not...
mdgm-ntgr
Sep 15, 2013NETGEAR Employee Retired
What does support suggest now? Sounds like further troubleshooting might require remote access to your unit. It's possible the 4GB OS partition may be getting full.
