PillNAS
Sep 13, 2013Aspirant
Factory Reset Help
Hello, I'm new to this so please bear with me........I have been trying to update the firmware on my ReadyNAS Duo V2 from 5.3.7 to 5.3.8. I have tried to update it using the Dashboard but this did not...
PillNAS
Oct 21, 2013Aspirant
Sorry it's taken so long to post an update. I contacted support and they are still in the process of sorting out my issue. It seems to take really long for them to get in touch with me to help.
I was wondering if anyone had a way of getting the data off one of my hard-drives. I think the quickest and best method maybe to do a factory reset.
I am by no means an expert so a step by step method would be really helpful. I know how to take the drive out and put it in an enclosure. Once I've done this if I connect it up to a windows PC will it appear as a external drive? Will I be able to access the data easily?
