peter_major
Jul 18, 2011Aspirant
Factory reset without losing data?
Hi there, i've been playing around with my Ultra 2 Plus... I installed a webserver on it and installed some other stuff by enabling ssh. After all doing all that, I've decided I just want to ret...
TeknoJnky
Jul 18, 2011Hero
boot menu reinstall will reset the network settings, and generally restore any files that may have gotten removed/buggered up by ssh mistakes, however it does not remove any extra stuff you install and most other settings are preserved.
In general it will get you up and going if you (or a bad addon) cause boot or system problems, but it does not 'clean house' so to speak.
