Supertramp11
May 03, 2016Luminary
Fan System in enclosure Internal speed is below threshold. (0 rpm) #26821415
Hi,
After having successfully used my ReadyNAS PRO 6 with OS 6.4.2, today I started to received the following allert message: Fan System in enclosure Internal speed is below threshold. (0 rpm)....
- May 18, 2016
Seems to be working O.K. since I updated it to 6.5.0. Can you confirm?
xjrguy
May 09, 2016Star
FYI I have the same problem. In a Ready NAS Pro and a Ready NAS Ultra Plus.
Both machines are running 6.5.0 RC3
Both have exhibited the problem since updating to 6.5.0
I've resolved it in both units by setting the fans to "COOL" and rebooting the boxes.
I will get a couple fan errors and it will then settle down.
I don't think it's your box so I wouldn't RMA if I were you. I did not have to play musical connectors with the fan headers on the board either.
Supertramp11
May 09, 2016Luminary
Thanks.
What I don't understand is that OS 6 has been working absolutely great on my PRO 6 and out of the blue, it starts to have this fan problem. Out of the blue since I did nothing with the NAS besides booting it up, streaming music and shutting it down.
As I have no physical access to the NAS this week, I will downgrade it to OS 4 when I'm home next week. If the problem persists, I will RMA it, if not I guess I have to stay on OS 4 :-(
- mdgm-ntgrMay 18, 2016NETGEAR Employee Retired
- Supertramp11May 18, 2016Luminary
Thanks mdgm.
Let me confirm this evening when I'm back home and have physical access to the NAS.
It would be great if OS 6.5 resolves this issue.
Assuming it does, can I just remove the scratch disk and put my regular (6.4.2) disks back in the NAS?
Many thanks for your support.
Yes. If you do that it would detect the firmware mismatch and install 6.5 onto the disks.
