Supertramp11
May 03, 2016Luminary
Fan System in enclosure Internal speed is below threshold. (0 rpm) #26821415
Hi,
After having successfully used my ReadyNAS PRO 6 with OS 6.4.2, today I started to received the following allert message: Fan System in enclosure Internal speed is below threshold. (0 rpm)....
- May 18, 2016
Seems to be working O.K. since I updated it to 6.5.0. Can you confirm?
Supertramp11
May 09, 2016Luminary
Thanks.
What I don't understand is that OS 6 has been working absolutely great on my PRO 6 and out of the blue, it starts to have this fan problem. Out of the blue since I did nothing with the NAS besides booting it up, streaming music and shutting it down.
As I have no physical access to the NAS this week, I will downgrade it to OS 4 when I'm home next week. If the problem persists, I will RMA it, if not I guess I have to stay on OS 4 :-(
mdgm-ntgr
May 18, 2016NETGEAR Employee Retired
- Supertramp11May 18, 2016Luminary
Thanks mdgm.
Let me confirm this evening when I'm back home and have physical access to the NAS.
It would be great if OS 6.5 resolves this issue.
Assuming it does, can I just remove the scratch disk and put my regular (6.4.2) disks back in the NAS?
Many thanks for your support.
