HiddenWolf
Aug 11, 2012Aspirant
Fastest way to restore data from backup after factory reset
I am preparing to do a factory reset of my Readynas Pro, as I want to upgrade to dual-redundancy and take advantage of the chance to clean out my config and move to ext4. I'm currently backing up m...
Aug 13, 2012Guru - Experienced User
It would be a nice feature if they had a restore button that reversed source and destination. Maybe you can add that to the new features requests.
Usually I have just done that manually.
BTW, it is important to reinstall addons before restoring the config.
