bobfa100
Apr 12, 2017Aspirant
Restoring a RN102 After Factory Reset
RN102
FW 6.7
RAID1 with two 4 TB drives
I had to factory reset my RN102. That went fine. Now I have 4TB of clean space.
Prior to the reset, the RN102 was backed up to an external 5TB drive.
I can read the USB drive with Paragon ExtFS for Windows. I see all the data, but the RN102 doesn't recognize this as a backup drive.
I remember seeing something earlier in the forum about copying some kind of backup configuration file from the USB to somewhere in the NAS file system. Can someone kindly point to this forum post or tell what to copy over, where to copy it to and how to make the RN102 recognize the backup.
Thanks for your kindness.
Bob
Hello bobfa100,
You are most welcome! If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- JennCNETGEAR Employee Retired
Hello bobfa100,
Please check this article: How do I back up data from a USB disk to my ReadyNAS OS 6 system?
- bobfa100Aspirant
Thanks JennC
Hello bobfa100,
