Tobias66
Dec 15, 2016Aspirant
firmware update doenst work
Hi
actual firmware 6.1.6
every restart message will prompt: upgrade to 6.2.5 -> ok
download works, restart, nothing to see.
no information about problems in systemlog
test with manually download fw 6.2.5 an update -> restart -> same problem
test wtih fw 6.6.0 -> same problem, no infromation eg.
didn't find infromation about this problem...
the first problem is -> usb hard drive will listet with modelname in logfile (not identified) but is'nt see in system overview to reformat the drive (2TB mybook)
reguards Tobias
Is your issue that the firmware updates failed? (That is the web ui still says you are running 6.1.6).
- Tobias66Aspirant
Yes, message FW Version 6.1.6.
Found another Thread (workaround):
Info under:
http://kb.netgear.com/29974/ReadyNAS-OS-6-RN100-RN2120-cannot-update-due-to-invalid-checksum?cid=wmt_netgear_organic
(Checksumproblem)But this works only from FW 6.1.9. Informatiosn about older Versions and resoultion -> link is broken.
Tobias
That article only applied to 6.4.0 upgrades.
Do you have any apps installed? Also is ssh enabled?
