Numb3r6
Oct 17, 2016Apprentice
Frontview and supported browsers
I'm confused. I'm sure I used to be able to use Google Chrome from both Win7 and Win10 PCs to access Frontview on my NAS.
The issue is one where it loads, after being presented with a warning about security certificates, but the console is minimal, with no active "buttons"
In experimenting I've noted the following:
From Win10 Pro/64 PC using Chrome 54.0.2840.59 m the problem happens
Same platform, Firefox 49.0.1, same issue
Same platform, Internet Explorer 11.0.1024017146, ignore the warning, Frontview behaves normally
iPad 3 Chrome app, ignore, the warning, Frontview behaves normally
Now I've tried the certificate key generation export/import thing from the NAS to Chrome on the WIn10 PC but that's not helped
I'll admit I am not well versed in the matter of certificates but arguably it shouldn't be this hard to get one of the most popular browsers to work correctly with Frontview!
If I'ver missed or misunderstood something then I stand to be guided!
Help!
Hello Numb3r6,
I don't think it has something to do with the certificates. It's definitely a browser problem as other web browsers do not get the same problem.
You may try downgrading the Chrome and Firefox web browsers that do not work normal with the FrontView.
- Numb3r6Apprentice
Thanks for the suggestion about the browser version. I can't claim to understand what changes come through in different releases or indeed what standard should be catered for when considering how the browser interfaces with products such as Frontview., but it was worth a look.
However, as I can't recall the exact date this started happening I used Filehippo to pull down an older Chrome version (non beta) at v54.0.2840.71 (32 bit)which was Jun16.
Whilst the irritating security warning still shows, I can ignore and the Frontview session works as it should!
For the record Raidiator is 4.1.15 and my main PC is running Chrome v54.0.2840.71 m (64-bit)
I guess it's just a bit hit or miss with each release of Chrome, and perhaps other browsers too, but at least I know I can revert to an earlier version to restore functionality now.
:smileyhappy:
FWIW, 54.0.2840.87 m works on my PC with 4.1.15.
Yeah. It's surprising that more stuff doesn't break, given the pace of the updates.
Can you post a screen shot?
- Numb3r6Apprentice
Thanks for the interest on this one. Here's a couple of shots:
Chrome (Firefox shows the same symptom)
and IE
as I said before, both give warnings about certificates and I tried to create/export/import into Chrome but it made no difference.
As for IE I just accepted the warning, carried on and the Frontview GUI is fine.
I'm really hoping I'm just missing something stupid here as I'm sure I've managed to get it working previously!
- JennCNETGEAR Employee Retired
Hello Numb3r6,
