SuperFlyBoy1
Feb 20, 2012Aspirant
Hardware Errors on Mirrored 750GB Seagate Disk on NV+(4.1.6)
Hi All,
I'm running 2 x 750 GB Seagate drives (as originally supplied on the NV+) one of which is exhibiting drive errors.
The NV+ reports current config as under:
Online, X-RAID, 2 disks, 71% of 688 GB used
Firmware: RAIDiator 4.1.6 [1.00a043]
This started when we moved PST files over to the NV+ to have clients access them online.
However, when indexing these PST files (with Lookout), then the NV+ would lock up and now the log is reporting the HD errors. (Only one disk reporting)
The only way to restart the machine was a forced shutdown, so the logs reflect this (Have not opened that Outlook client, due to the fact that it locks up the NV+, which is why there are no problems since the 17 Feb note in the log):
Fri Feb 17 04:00:07 IST 2012 ATA error count has increased in the last day. Disk 2: Previous count: 1656 Current count: 1677 Growing SMART errors indicate a disk that may fail soon. If the errors continue to increase, you should be prepared to replace the disk.
Thu Feb 16 12:44:03 IST 2012 RAID sync finished on volume C. The volume is now fully redundant.
Thu Feb 16 04:00:05 IST 2012 ATA error count has increased in the last day. Disk 2: Previous count: 0 Current count: 1656 Growing SMART errors indicate a disk that may fail soon. If the errors continue to increase, you should be prepared to replace the disk.
Wed Feb 15 21:44:01 IST 2012 System is up.
Wed Feb 15 21:15:03 IST 2012 RAID sync started on volume C.
Wed Feb 15 21:14:22 IST 2012 Improper shutdown detected. To ensure data integrity, a filesystem check should be performed by rebooting the NAS through Frontview with the volume scan option enabled.
Wed Feb 15 16:42:47 IST 2012 System is up.
Wed Feb 15 16:09:07 IST 2012 RAID sync started on volume C.
Wed Feb 15 16:07:37 IST 2012 Improper shutdown detected. To ensure data integrity, a filesystem check should be performed by rebooting the NAS through Frontview with the volume scan option enabled.
Wed Feb 15 14:05:22 IST 2012 A SATA reset has been performed on one or more of your disks that may have affected the RAID parity integrity. It is recommended that you perform a RAID volume resync from the RAID Settings tab ( accessible in the Volumes page => Volume tab in FrontView ). The resync process will run in the background, and you can continue to use the ReadyNAS in the meantime.
Wed Feb 15 14:05:07 IST 2012 Access to the disk on channel (??) is producing I/O errors. Although the array is still redundant, please replace this drive as soon as possible, as it is likely to fail soon.
If we are currently on X-RAID, then I could just slip in another disk and it should become redundant, allowing me to remove the one bad disk - or do I need to add 2 more disks?
However, I just purchased 2 Western Digital 2 GB disks, which this firmware (4.1.6) might not be able to handle, right?
I know I should do a backup before updating firmware, so need to know whether the NV+ would recognize the 2 TB Western Digital Caviar Blacks (WD2002FAEX) as they are?
Thanks for any feedback on this!
- mdgm-ntgrNETGEAR Employee RetiredTo use disks greater than 2TB in capacity you'd need a new NAS.
However what I'm saying is that you should backup your data and do a factory reset to get 4k sector partition alignment. That way you don't have to worry which 2TB disks you purchase so long as they're on the compatibility list. If a disk fails you again just have to look for one on the compatibility list to replace it. - SuperFlyBoy1Aspirant
mdgm wrote: To use disks greater than 2TB in capacity you'd need a new NAS.
Right - understood.
I'm not sure I have the time to do the reset on the NV+ at this time - I think I am looking at a NAS which can backup to CrashPlan - which this one definitely cannot do, so then the extra effort is moot. - mdgm-ntgrNETGEAR Employee RetiredCould still use this NAS as a backup NAS. Once you've migrated your data to a new NAS, update to 4.1.7 or later and do a factory default and then use the NV+ for a local backup of important data.
x86 ReadyNAS e.g. Ultra, Pro can be used with Crashplan though you'd need to enable SSH access to install it etc. - SuperFlyBoy1Aspirant
mdgm wrote: Could still use this NAS as a backup NAS. Once you've migrated your data to a new NAS, update to 4.1.7 or later and do a factory default and then use the NV+ for a local backup of important data.
Right - this unit is on 4.1.8 at present.
We will see how things progress - no funds to invest in another at this time...these hard drives are pretty expensive over here. - mdgm-ntgrNETGEAR Employee RetiredWell if you can't do the reset and can't get a new NAS, make sure NOT to buy drives that are 4k sector (advanced format). Make sure you buy 2TB drives that are 512-byte drives.
I agree that it is easier/more convenient to have 4K alignment. Otherwise you have to research each 2 TB drive purchase, and the new format is already becoming mainstream on new drive models. Also (assuming this is inevitable/in your future anyway) it is much better to rebuild the array when you know the disks are good.mdgm wrote: ... That way you don't have to worry which 2TB disks you purchase so long as they're on the compatibility list. If a disk fails you again just have to look for one on the compatibility list to replace it.
CrashPlan is good, esp. for disaster recovery. However, it is not as fast as local backup. Also, the Crashplan folks do not recommend using only one backup site. So I use my older duo/NV+ units to backup my pro, which is also (very recently) being backed up with crashplan.SuperFlyBoy wrote: I'm not sure I have the time to do the reset on the NV+ at this time - I think I am looking at a NAS which can backup to CrashPlan - which this one definitely cannot do, so then the extra effort is moot.
BTW, with some effort it might be possible to use a PC with Crashplan to backup the NV+ (mapping the shares as a network drive). CrashPlan does not officially support this, but they do provide a guide here: http://support.crashplan.com/doku.php/r ... ped_drives. I haven't tried it myself though. - SuperFlyBoy1Aspirant
StephenB wrote: BTW, with some effort it might be possible to use a PC with Crashplan to backup the NV+ (mapping the shares as a network drive). CrashPlan does not officially support this, but they do provide a guide here: http://support.crashplan.com/doku.php/r ... ped_drives. I haven't tried it myself though.
Yes, I'm doing something similar with LiveKive (AVG) for one of the directories that are most important.
Will try to look at your link when I have time - thanks for that! - SuperFlyBoy1AspirantNow I have 3 x 2 TB WD disks installed as under:
RAID Disks:
Ch 1 : WDC WD2002FAEX-007BA0 [1862 GB] 694 GB allocated
Ch 2 : WDC WD2002FAEX-007BA0 [1862 GB] 694 GB allocated
Ch 3 : WDC WD2002FAEX-007BA0 [1862 GB] 694 GB allocated
However, how do I ramp them up to their full capacity of 1862 GB - a hard reset after backup - is this the only way? - mdgm-ntgrNETGEAR Employee RetiredWhat is the volume status? Is it redundant?
If so, have you tried a reboot? - SuperFlyBoy1Aspirant
mdgm wrote: What is the volume status? Is it redundant?
Yes, it's redundant now.mdgm wrote: If so, have you tried a reboot?
Not after installing the third disk in the original position (Slot 1) of the 750 GB Seagate - the one that wasn't failing.
That one is now removed, in case it also starts to act up and because posts here mentioned (or as I understood) that it might limit the capacity of the other 2 TB drives...
Do slot positions even matter?
