SanderK
Aug 23, 2011Aspirant
HELP: how do I abort factory reset on NV+
I have accidentally selected the wrong Readynas for a factory reset, for some reason I had 2 webinterfaces open of 2 different devices and I selected the wrong one. The power cable of my NV+ was pu...
mdgm-ntgr
Aug 23, 2011NETGEAR Employee Retired
When you initiate the factory reset, the NAS reboots performs a few checks and then starts a 10 minute countdown. So long as you power down (however you can e.g. pulling the power) before the 10 minute countdown finishes the factory reset is aborted.
So you did the right thing.
