SanderK
Aug 23, 2011Aspirant
HELP: how do I abort factory reset on NV+
I have accidentally selected the wrong Readynas for a factory reset, for some reason I had 2 webinterfaces open of 2 different devices and I selected the wrong one. The power cable of my NV+ was pu...
blaize
Nov 30, 2011Aspirant
Well I worked out how to do the OS reinstall which went fine and now it says its resyncing the volume raid 5 and has 10 hours to go (4 x 1TB drives) so fingers crossed it has saved my volume, I guess time will tell it did reset my hostname and IP settings but I guess that would be expected????
I will post how it goes one way or another.
