grish4
Apr 15, 2017Aspirant
how long does it take to OS reinstall ?
hello,
I began an OS reinstal 7 hours ago and the NAS still showing a "booting... updating FW" message. What's the next step ?
thank's for your help.
grish4
Updated the firmware to 6.7.1 Beta 2 and was able to mount the data volume with the option to disable volume quotas fine.
Rebooted it to normal mode and it came up fine.
Oh and for good measure I updated the BIOS to the latest.
- jak0lantashMentor
Can you explain why did you start an OS Reinstall? That's most likely important information to understand what's happening.
- grish4Aspirant
Hi,
booting stop on 31%.
That's why I tried to reinstal the OS.
Can it be useful to tempt this two or three times ? there's nothing on it that I can't loss, but I wan't try all procedure existing before the factory reboot.
Is USB key restart the next candidate ? does that erase data ?
is it useful to try a boot with no disk ?
thanks
- jak0lantashMentor
USB Boot Recovery is to rewrite the flash, I doubt it would help in this case.
Booting without disk is pointless as the system and settings are on the disks.
31% seems early stage though. Anything happened before this condition?
Maybe you should contact NETGEAR Support... Especially if you don't want to take any risk with your data.
An OS reinstall should take a couple of minutes at most.
Do you have a backup of your data?
- Jul 15, 2018Retired_Member
