tlyczko
Feb 07, 2011Tutor
how to enable Online File System Consistency Check??
We have two ReadyNAS Pro 'Business Edition' NAS boxes, each with 6 disks. The first was purchased late 2008 and recently had its disks replaced, since one went bad and the remaining two were no lon...
JosephAE
Oct 06, 2011Aspirant
My PRO Business is failing the consistency check regularly. When I reboot and run the full file system consistency check everything passes without errors. I’ve also gotten reports that snapshot space was no longer allocated.
Is it possible that there is something running on my NAS (even on Sunday at 2:00 am) that is exceeding my snapshot space thereby causing my problem? Or do I have file system errors in the partition of the hard drive that's allocated for snapshots?
Is there something I can do to fix this issue?
Thanks for any help possible.
