komm_it
Aug 29, 2018Guide
JBOD (Single)-function (2 HDDs as 2 independent drives) on USB
Hello,
I'm trying to set up a JBOD box (IcyBox IB-3662U3) with 2 HDD as 2 independent drives on a one of the USB port.
The RN31600 only recognize 1 HDD. Windows or MacOS recognize and mount both Ext4 HDD.
Is there anyway I can make ReadyNAS 6.9.3 system recognize both HDD?
Thanks
komm_it wrote:
Well, perhaps a new 4 drives NAS set up as JBOD is actually a better / safer solution…
I think it is safer, but your approach does allow you to remove the drives and access them directly with ext, which is a plus.
- mdgm-ntgrNETGEAR Employee Retired
I don't think so.
Btw if you download the logs what is the date in bios_ver.log?
