lopezl
Jan 20, 2016Follower
lifesupp! message
Hi, I got this message, "lifesupp! message", while doing a resync (complete history follows) and I think I need some help from experts due the previous messages in this forum about this error. ...
- Jan 25, 2016
You run into a very common problem. Your drives report okay to the ReadyNAS until heavy operations take place (like resyncing RAIDs). When you have to resync the RAID, it manuevers through all the disks and reads sectors that maybe weren't read in a long time.
Anyway, while you're resyncing a new disk, bad parts of the old disks make themselves visible. You can catch these usually by running a scrub maybe a few times a year. Running the scrub will help you find disks that have problems sooner than later.
Also, you should always have a backup of your important data. A single point of failure is simple that.
kohdee
Jan 25, 2016Administrator
