claytonb
Aug 03, 2017Aspirant
Login to NAS
Hi, I keep getting this message logging into my NAS, how can I fix it?
- Aug 05, 2017
Hi,
Don't worry about this message. It happens because the NAS uses a self-signed certificate for https. You can just click "Go to webpage".
However, if you see this message on actual webpages on the internet then DON'T continue :)
JennC
Aug 03, 2017NETGEAR Employee Retired
Hello claytonb,
This concern you have is the same as what was discussed at this another another discussion thread. It is basically an error when accessing your ReadyNAS admin page that uses local IP that is not known on the Internet. Either you click the GO on to the web page hyperlink or add a certificate. I suggest you visit the hyperlink I sent for more information.
