Irfanshaik026's avatar
Dec 15, 2025
NAS RN 214 showing data degraded error
As my NAS RN 214 suddenly showing data degraded error on screen of device and it is blinking, since login in the NAS and found one of the hard drive showing offline ( no green color ) . Kindly help with suggestion for further solution.
  • "Degraded" simply means that you no longer have RAID redundancy, not that your data is corrupted yet.  That one drive is offline is likely indicating that drive has failed.  But if another failure occurs before you restore redundancy by replacing the failed drive, your volume will be lost.  If you don't already have one, your next step is to back up your data.  The re-sync that occurs when you replace a drive puts a load on the others and can result in one of them failing, especially if they are at least as old as the one that already failed.  And if that happens, you volume is dead.  Something you should not do is cycle power or do a restart. If the NAS then sees the failed drive, which can happen when it re-initializes, it will start a re-sync, which will likely fail but puts a strain on your other drives and can end in an incomplete resync and dead volume.
    • StephenB's avatar
      Sandshark wrote:
      if you don't already have one, your next step is to back up your data.
      Agreed.  Your data is at risk.
      If you don't have enough space to back up everything, then start with files that are irreplaceable (family photos, personal records, etc) while you are waiting for more storage to arrive.
  • StephenB's avatar
    Generally this is a result of a disk failure.
    Download the full log zip file from the logs page.  You can see SMART statistics in disk_info.log, and also see disk errors in systemd-journal.log.
    If you aren't seeing clear signs of a disk problem, then let us know.
    Best options for replacement are NAS-purposed drives (WD Red Plus, Seagate Ironwolf, Toshiba N300 series) or enterprise class.  Don't use desktop drives, as many are now SMR and don't work well with ReadyNAS.
ProSupport for Business
