gdn
Jan 05, 2016Aspirant
Need advice about resetting to Factory Default on rn104
So, after the 40th forced resync since upgrading to 6.4 on my rn104 (system hangs/freezes and I have to unplug&plug the power), I decided to do a reset to factory default. My setup is the following,...
- Jan 05, 2016
I think that is quite likely. I would give the beta a try.
mdgm-ntgr
Jan 05, 2016NETGEAR Employee Retired
Your procedure won't work. RAID provides redundancy not backup.
With 4 disks in X-RAID2 (single-redundancy) you would need 3 of the disks to be able to access the data.
Have you tried 6.4.2 beta yet?: ReadyNASOS 6.4.2-T59 (Beta 1)
Can you send in your logs anyway (see the Sending Logs link in my sig)?
Happy New Year and Welcome to the Community!
- gdnJan 05, 2016Aspirant
Thank you for your reply, I just sent the logs.
No, I haven't tried it yet.
I read "Fix potential hang on RN104 due to a race condition when using the CPU's RAID5 offload engine."
Could be this the issue of my RN104?
- mdgm-ntgrJan 05, 2016NETGEAR Employee Retired
- gdnJan 07, 2016Aspirant
Well, updating the firmware seems to have fixed the issues it had: I managed to resync in normal mode (previously, I always had to reboot in read only) and to move files without freezing
