gdn's avatar
gdn
Need advice about resetting to Factory Default on rn104
So, after the 40th forced resync since upgrading to 6.4 on my rn104 (system hangs/freezes and I have to unplug&plug the power), I decided to do a reset to factory default. My setup is the following,...
  • mdgm-ntgr's avatar
    mdgm-ntgr
    Jan 05, 2016
    I think that is quite likely. I would give the beta a try.
ProSupport for Business
