Mr_B
Nov 26, 2012Guide
Netgear ReadyNAS 1100 - spec's and limitations?
I got offered one of these for a fair price, but i suspect they are getting rid of them just in time. They are Readynas NV+ relatives, sparc based, 2TB / drive limit applies and so on? How is the perf...
mdgm-ntgr
Nov 26, 2012NETGEAR Employee Retired
Mr_B wrote: Any idea on what firmware is the latest, and where / if anyone could get their hands on it? On a working unit, is there anything special one should know to look for? I managed to find a few images online, it looks like it uses a socket for the memory, just as the NV+ does.
Here you go: http://www.readynas.com/RAIDiator_4_1_10_Notes
Mr_B wrote:
Whats with the "internal USB key"? Is it instead of having a bit of flash on the motherboard, or creating a boot partition on the array for the system? Can/should one make a backup, does size & speed of said stick matter? (More then likely the size is an issue of having to large sticks, rather then not large enough. Would this be an issue)
The firmware is installed from the flash onto the OS partition on the disks. The flash is used during the early part of the boot process. No need to do a "backup" of this key. Easy enough to write the firmware to a replacement USB key if necessary (should be a 128MB or greater capacity one, 64MB is just enough)
