elinenbe
Dec 05, 2009Aspirant
NV 4x1TB -> 4x2TB nightmare! (#10777660)
Here's what I have done so far
I have a readynas NV
It has 4x1TB (xraid) 4.1.6
1) I bought 4 new 2TB drives
2) Replaced each drive one at a time
3) Rebuilt successfully after each drive replacement
4) RAID begun expansion after 4th drive was put in.
5) Never properly expanded
6) Found out I had the wrong block size so, I would need to do a factory reset (a very old device)
7) Backed up ALL data to external hard drives
8) Factory reset
9) Rebuilt okay
10) Restored old config
11) Became unresponsive
12) Factory reset again -- unresponsive -- says root corrupted
13) USB reset -- looks like it works.
14) reboot, I get two LEDs blink, then four LEDs, then two, etc...
15) check dimm -- seated okay
15) try tFTP reset -- loads up okay
16) upon reboot, it never comes back up.
17) reboot, I get two LEDs blink, then four LEDs, then two, etc...
18) USB reset -- looks like it works.
19) reboot, I get two LEDs blink, then four LEDs, then two, etc...
Please help. These are new drives, and work fine outside of the NAS with no problems. I'm at ends wit!
Thanks,
Eric
8) Factory reset
9) Rebuilt okay
Thanks,
Eric
- dbott67GuideI don't really have any advice other than to download the logs regularly (it may contain some insight as to what's happening). Keep us posted.
- elinenbeAspirantI'll do that now, then after this third disk is done initializing, and then after a reboot. This initializing should be done in ~6 hours.
- elinenbeAspirantOK. I was going to attempt to grab the logs after the expansion of the data volume after the third disk initialized.
However, I'm now in some sort of repetitive loop where every couple of seconds the ReadyNAS web interface comes up with a box that says "Data volume has been successfully expanded to 3707GB" I click the box, and it does it's thing for a minute, then pops the box back up. RAIDar shows the icon under disk 2 blinking and the info says "Expanding". When I hover over in RAIDar it says resynch 0% complete, time to finish -99 minutes. I'm viewing it remotely so I can't pull the power. I also can't reboot via the web interface or pull the logs -- the interface isn't really responding since that text box keeps coming up.
I'm getting incredibly frustrated.
-Eric - elinenbeAspirantI've come home from work, and it's currently impossible to access the unit via the web GUI. The box keeps popping up, and RAIDar reports -99 minutes to go. It's been doing this for hours, so I'm rebooting...
Rebooted...
"corrupt root". Again.
Now I'm trying something different. I just put all 4 drives into the unit, and am doing a factory reset -- will try just standard RAID5. - mdgm-ntgrNETGEAR Employee RetiredThis is concerning. It shouldn't be doing this.
Just a long shot, but could you try a memory test: faq.php#Is_there_a_way_I_can_verify_if_my_memory_is_good%3F - elinenbeAspirantOK. I tried RAID5, and I am STILL at "CORRUPT ROOT" I've sent two sets of logs off to Netgear (one from during the rebuild, and one from after the rebuild, but during the sync) It seemed to work this time, so I created a couple of shares, and begun to start copying data to the NAS. However after just a couple of minutes the shares became inaccessible vis SMB/CIFS, though I could still access the device through the web interface. Well, at least I thought I could. No matter what I clicked or changed, didn't affect anything, and I couldn't reboot via the GUI.
It finally stopped responding, so I rebooted the device using the power button.
It came back up as "corrupt root" again.
Ug...
I can no longer pull logs from the device.
-Eric - mdgm-ntgrNETGEAR Employee RetiredHave you tried the memory test? Do you have the stock memory module installed?
- elinenbeAspirantNot sure. I think it is fine -- well I ran the memory test, and I'm not sure if it ran all the way through or not, but then the readyNAS rebooted itself, and then began blinking the first two green LEDs, then all four, then the first two, then all four...
This is a 1GB memory upgrade from the original memory, but I've been running with this for nearly 4 years. - mdgm-ntgrNETGEAR Employee RetiredDo you remember which memory you are using? i.e. make and model.
If you still have the stock 256MB RAM module could you try putting that in the ReadyNas and seeing if you still get the corrupt root error? - elinenbeAspirantOK. So I did a factory reset again from USB (held down the back reset button for 20+ seconds on reboot), and let it go from there. I started with all four drives in, and set it up as an XRAID. The unit seemed to go through the paces, and everything SEEMED to be working. I changed the IP from dynamic and the hostname, and enabled jumbo frames. Then I rebooted the device. Upon reboot, it's no longer acessible in the web, and now RAIDar shows the firmware as 4.01c1-p6 -- no clue how this happened. The USB stick I have, has the most recent firmware, and the drives were wiped clean with all partitions removed before this latest attempt.
Also, the Netgear support hasn't gotten back to me in almost 4 days, so I'm pretty much left hanging with $800 in drives, and a unit that seems not to accept them no matter what I do.
