GlueGuy's avatar
GlueGuy
NV+ backup/expand/restore
After living happily with our NV+ for several years, we are now ready to expand the storage. We currently have a 1TB config (4 by 250MB XRAID), and plan to replace the HDs to a total of 4TB (4 by 1TB).
I know that we should be able to swap the drives one at a time, but it seems it would be a lot quicker to just backup the whole thing to a USB-attached drive, swap all the disks at one time, then restore from the USB.
So. Backing up to the USB looks super simple. Plug in the USB, and push the button.
I'm cool with swapping all the drives.
Then.... What's the simplest, most reliable way to restore the whole thing on the new, larger space?
I've looked all over the place, but have not been able to find anything about restoring a ReadNAS from a USB drive? :(
Perhaps I'm not asking the question properly?
TIA!
GlueGuy
  • I don't know that there is a proper way to interrupt expansion.
    Expansion to that size volume should be complete within 24 hours.
    You have a good backup so you could perhaps interrupt it at an earlier stage if you thinks it's hung.
    You may find that after a reboot it starts expanding again.
  • So this could take up to 24 hours?!?! Seems like a really long time considering that all the other steps only took a few hours.
    So the suggestion is to let it go for a while longer? Up to 24 hours? And if it's still in the same state, then reboot it? Via the power button?
    BTW - Is this web site always this flaky? It's been unavailable several times today (at least for me). Checking it from other places (like http://www.isup.me/readynas.com) says it's the readynas.com site is unavailable.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    If you last did a factory reset on RAIDiator 3.x (sounds likely from what you've posted) it is probably doing an offline expansion. Expansion can take a long time. Is it still stuck at the same percentage?
    Our RAIDar is 3.01c1-p1. I'm not sure we've ever updated it.
    It stayed stuck at 1.3% from ~~ 8:30 AM until almost 5PM, then suddenly jumped to 17.2% (I was not there when it moved).
    Then around 6PM there was another jump to 61.7%. It's now about 6:20PM, and it's still stuck at 61.7%.
    Kind of stunning that it's been almost 10 hours with virtually no signs of life (other than the repetitive blinking lights on the front panel).
    mdgm-ntgr
    RAIDar is the client app you run on your PC.
    RAIDiator is the NAS firmware
    When you open Frontview when the NAS is working does the interface show Infrant or has it been rebranded as NetGear?
  • We got it from Netgear, and it says Netgear everywhere.
    Frontview says RAIDiator 4.1.13 [1.00a043]
    Power supply fragged a year or so ago, and we got a whole new chassis from Netgear at that time. Just swapped the HDs from the old box to the new box.
    BTW - Expansion completed. Now says we have 2738 GB. That seems kind of low for 4x1TB disks?
    Each disk is 927 GB *4 that should come up somewhere in the 3.7 TB range shouldn't it?
  • StephenB's avatar
    It's xraid (e.g., raid-5) so its about 927 x 3 GB - quite close to what you have. The remaining 927 gb is for redundancy.
    mdgm-ntgr
    Considering you are running a several year old version of RAIDar I was hoping you weren't also running an ancient version of RAIDiator. Good to see that you are running the latest version of RAIDiator for your NAS.
    I think X-RAID on Sparc uses RAID-4 but your volume capacity is what is expected like StephenB says.
    I love logical explanations.
    Thanks again!
ProSupport for Business
