JimG1
Dec 02, 2015Guide
OS 6.4.1 slow ... to the point of unusable
We just upgraded an RN102 to 6.4.1, which intially seemed to fix some backup issues we'd been working around, however we've just downgraded to 6.4.0 after seeing 6.4.1 being too slow to be usable (the downgrade fixed this issue). By slow I mean in navigating file trees and serving files. Has anyone seen this?
To get the fix for the anti-virus issue you can update to ReadyNASOS 6.5.0-T338 (Beta 2) (or later). Alternatively if you prefer you can stay on 6.4.2 for now and install the hot-fix (which is now available).
Thanks for your patience.
Hi All,
I have had the same issue, however mine got so bad i decided to a factory reset! that didn't work. I have been really dissappointed with this F/M release. Mt NAS is unusable. Seeing this thread I am trying to down grade to 6.4.0 now. Will let you know how it goes.
I was at the point of wanting to sell the NAS and just use Dropbox.Having been a loyal NAS FAN for Netgear for over a decade I am at the point of trying something new. these lates Software bugs are so frustrating!
- mdgm-ntgrNETGEAR Employee Retired
There is a fix in ReadyNASOS 6.5.0-T338 (Beta 2) for the anti-virus issue as well as some other fixes. Please try it.
- Hunt_trexAspirant
The update fixed the issue. Gee thanks Netgear for all the frustration and wasting my time trying to troubleshoot an issue the should never have happened. This is very frustrating and made me question if I will purchase a netgear product in the future.
Once again thinks for wasting my time.
- kohdeeNETGEAR Expert
There's going to be an article released sometime extremely soon for 6.4.0-6.4.2 and the Antivirus updates to address lots of the complaints Antivirus caused. Please be on the lookout. I'm sure someone'll post the article later once it is approved. :)
- Peter_the_HatAspirant
Hi ,
I installed 6.5.0 beta 2 on my 314 5 days ago and the slow problem with the AV enabled is now OK. all is working at normal speed as far as I can tell.
Peter
- Hi all readers and special testers,
Are more users enthousiast?
Please, we complain so we also should shout out when the solution works. - amtrakuk1Aspirant
Installed 6.5.0-T338 (B2) and enabled the AV. All seems rine on my 104
- fkhanAspirant
issue seems to be fixed now
thanks RN team.
is the new OS 6.5 out of the Beta stadium and also working on the 100 serie?
Who has the experience?
