adamwilt
Jan 15, 2017Aspirant
OS 6.6 on Ultra 6:. Not ready for prime time? Do I need more memory? Or...?
TL;DR version: OS 6.6 is worryingly unpredictable/unstable on my Ultra 6. Do I just need to expand the memory past the stock 1 GB, or is OS 6 still not ready for prime time, at least on these older b...
- Feb 05, 2017
Final update (I hope): I re-ran the upgrade from 4.2 to 6.6.1. The NAS has been working perfectly for over a week. What was different this time? (a) all disk were in place already, so no RAID expansion was needed; and (b) I went straight to 6.6.1, not 6.6.0.
I did order more memory, but haven't installed it; I'm still running the stock 1 GB. I wanted to replicate my previous issues first so I could verify whether increasing RAM alone would fix it. But the box has resolutely failed to show any issues at all: no hangups, no unexpected slowness, no failures to respond. I've tried things like running a scrub while launching backups and hitting the NAS with clients, and the system reacted more slowly when all that was going on, but even so: it all worked, and the scrub of 8.8 TB finished within 48 hours (as did the initial full backup, before I started the stress test). Incremental backups run as quickly now as they did on OS 4.
So I either had a subtle corruption during the initial upgrade, or stuffing two new disks in and expanding the volume triggered the problems. But it wasn't low RAM, apparently, and OS 6 seems to be running fine despite my best attempts to break it. I'm going to label it "bug report closed: cannot replicate."
As for the apparent mislabeling of the System and CPU temperatures? I edited /etc/frontview/sensors/ULTRA6.conf and swapped the "System" and "CPU" labels for temp2 and temp3, ran "systemctl restart readynasd", and now the readings in the web UI match the values I expected from version 4.2 (I got the idea from this thread: <https://community.netgear.com/t5/Using-your-ReadyNAS/ReadyNAS-4200V2-OS6-6-1-fan-control/m-p/1219655#U1219655>).
mdgm-ntgr
Jan 15, 2017NETGEAR Employee Retired
Can you send in your logs (see the Sending Logs link in my sig)?
- adamwiltJan 15, 2017Aspirant
Logs sent! Big backup is now running, and memory looks like this:
KiB Mem: 1003856 total, 968444 used, 35412 free, 2448 buffers KiB Swap: 2093052 total, 17844 used, 2075208 free. 492368 cached Mem
- JophusJan 15, 2017Luminary
I also have upgraded my Ultra 6 to 6.6.1 - CPU temp is locked at 35 degrees and doesn't budge. The system temperature is varying over time based on conditions - but seems incorrect.
HDD temps are 35-36 or so
CPU doesn't move from 35
System at 47-50...
- kekegsmJan 16, 2017Guide
I found a file:
This is my conf. CPU temp is everything low (max 15-16 celsius), i'm sure it is wrong. (heatsink is warm-hot, with Arctic MX4 paste and a 40x40x10mm Noiseblocker XM2 fan, what is plugged the connector near chipset):
chip "coretemp-isa-0000"
label temp2 "CPU"
# compute temp2 @%30, @%30
ignore temp3chip "it8721-isa-*"
ignore in0
label in0 "V+12"
compute in0 @*4, @/4
set in0_min 10.8
set in0_max 13.2
label in1 "V5_0"
compute in1 @*1.68, @/1.68
set in1_min 4.75
set in1_max 5.25
label in2 "V3_3"
compute in2 @*1.649, @/1.649
set in2_min 3.135
set in2_max 3.465
ignore in3
label in4 "V1_2"
set in4_min 1
set in4_max 1.3
ignore in4
label in5 "V1_8"
set in5_min 1.5
set in5_max 2.1
label in6 "V-12"
compute in6 @*19-50.4, (@+50.4)/19
set in6_min -13.2
set in6_max -10.8
set in7_min 3.135
set in7_max 3.465
label fan1 "CPU"
ignore fan2
label fan3 "System"
set fan1_min 1500
set fan1_max 2000
set fan3_min 850
set fan3_max 1500
ignore temp1
label temp2 "System"
set temp2_min 1
set temp2_max 80
ignore temp3
ignore intrusion0
