Stanman130
Apr 03, 2014Guide
OS6 Data Recovery - How to Mount BTRFS Volumes
I recently purchased a ReadyNAS 314 and 5 Seagate ST2000VN000 hard disks (one as a cold spare). I work as a system administrator, so I've been reading up on OS6 before I entrust this new system with m...
ArctiX
Mar 28, 2017Aspirant
Hey mdgm, thanks heaps for your help!
You're completely right! It was the combination of not creating a share folder in the NAS first, and also incorrect permissions for the video file.
I reset all owner/permissions for the folders/files recursively using
Chown -R admin <folder>
Chmod -R 755 <folder>
I'll probably look at setting correct permissions that coincide with the network through the frontend. As suggested with your link.
Thanks again for your help!
