Stanman130
Apr 03, 2014Guide
OS6 Data Recovery - How to Mount BTRFS Volumes
I recently purchased a ReadyNAS 314 and 5 Seagate ST2000VN000 hard disks (one as a cold spare). I work as a system administrator, so I've been reading up on OS6 before I entrust this new system with m...
JMehring
Apr 04, 2014Apprentice
If you have an array of 6 disks, do they need to be placed on the same disk device port (/dev/sdaX) as on the ReadyNAS or is mdadm smart enough to figure that out?
Since I need to do a factory reset anyway and I have 6 other disks sitting around I figure I could just move the 6 disks that are in the ReadyNAS to a PC instead of doing a backup, then once I populate the ReadyNAS with 6 new disks I could just restore from the PC using the original disks.
