Stanman130
Apr 03, 2014Guide
OS6 Data Recovery - How to Mount BTRFS Volumes
I recently purchased a ReadyNAS 314 and 5 Seagate ST2000VN000 hard disks (one as a cold spare). I work as a system administrator, so I've been reading up on OS6 before I entrust this new system with m...
mdgm-ntgr
Jul 20, 2014NETGEAR Employee Retired
Oops. Yes, you're right. It is btrfs-tools.
What do you see when you do a
when using RAID-6?
Are you entering the correct path.
/dev/md0 is for the OS partition
/dev/md1 is for swap
Then e.g. /dev/md127 is what the data volume is on.
If you do the flowing what do you get?:
# cat /proc/mdstat
when using RAID-6?
# btrfs fi label /dev/md127
