Stanman130
Apr 03, 2014Guide
OS6 Data Recovery - How to Mount BTRFS Volumes
I recently purchased a ReadyNAS 314 and 5 Seagate ST2000VN000 hard disks (one as a cold spare). I work as a system administrator, so I've been reading up on OS6 before I entrust this new system with m...
mdgm-ntgr
Jul 28, 2014NETGEAR Employee Retired
You may need a newer kernel and/or btrfs-tools.
Although the ReadyNAS uses kernel 3.0.x there is a lot backported from newer kernels. btrfs-tools is regularly updated.
You could try updating your Debian install to a newer kernel and also updating to the latest btrfs-tools and see if this helps.
In a data recovery situation you would want to do this before connecting the disks from the array.
