Stanman130
Apr 03, 2014Guide
OS6 Data Recovery - How to Mount BTRFS Volumes
I recently purchased a ReadyNAS 314 and 5 Seagate ST2000VN000 hard disks (one as a cold spare). I work as a system administrator, so I've been reading up on OS6 before I entrust this new system with m...
mdgm-ntgr
Jul 29, 2014NETGEAR Employee Retired
If the NAS hardware failed under warranty you should be able to get it replaced under RMA.
That kernel version is too old. You need to update to a newer kernel or manually backport a whole lot of patches.
See https://wiki.debian.org/HowToUpgradeKernel
I would suggest trying at least kernel 3.14
You may also need to install a newer version of btrfs-tools.
What output do you get if you run
# btrfs version
