Stanman130
Apr 03, 2014Guide
OS6 Data Recovery - How to Mount BTRFS Volumes
I recently purchased a ReadyNAS 314 and 5 Seagate ST2000VN000 hard disks (one as a cold spare). I work as a system administrator, so I've been reading up on OS6 before I entrust this new system with m...
mdgm-ntgr
Jun 21, 2015NETGEAR Employee Retired
Well in the ReadyNAS at least if you have several separate volumes they could be mounted concurrently.
Was your volume an X-RAID or RAID-1 volume or were you using a separate volume for each disk?
With just the one volume if the partitions are out of sync then mdadm will typically choose to start the array using one disk not the other. So if you want to try the other partition in such a case you would need to stop the array and start the array again specifying the partition on the disk you want to use.
The root and swap use RAID regardless of whether that is used for the data volume.
