stoya03
Nov 02, 2012Aspirant
Partion create failed after factory reset
I have forgotten the username and password to log onto my NVX, it is not the default values, so i was looking to factory reset the device. When i run through the steps to do this, the device fails ...
mdgm-ntgr
Nov 02, 2012NETGEAR Employee Retired
Same way you'd do a factory default except when you access the boot menu you hit the backup button till you see the OS Re-install option then hit the reset button again. See http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu#nvx_nvx_pioneer_edition
