Weevil1's avatar
Weevil1
Poor streaming connection/speed
ReadyNAS NV+ v2
WNDR4500
2 x Powerline AV500
Tvix N1 Network Player
Hello. My first post at the ReadyNAS forum (previous Stora owner!).
I hope someone can help me; I'm getting really frustrated with my 'streaming experience'. Alot of folk out there seem to be able to stream HD using the ReadyNAS, so when my Stora had problems, I decided to 'upgrade' to the NV+ v2. I have spent quite a lot of money with Netgear trying to play HD media over my network; over the past few months I have been slowly upgrading my older Powerline adapters to the AV500, invested in the WNDR4500, as well as moved 'up' (?) from the Stora to the ReadyNAS, but I still cannot play HD video from the ReadyNAS through the WNDR4500 and Powerlines to my Network Player.
I did have a gigabit switch (at the Network Player end of the Powerlines so my Sky box can get online, but even with this now removed from the 'pathway' there is no improvement.
I know it's not an issue with the player as the same file will play beautifully (even at double speed) when I attach a USB2 drive directly to the player.
There is such a wealth of settings that could be made within the router and the ReadyNAS, so I'm hoping someone could give me some guidance? I have also upgraded all my cables to CAT6 (there are a couple of CAT5 but these should be OK?)
My setup is pretty basic...
ReadyNAS ---> Router ---> Powerline ---> Powerline ---> Network Player
The Powerlines are both plugged directly into the mains (no extensions). All the devices I have should (according to the literature) be capale of supplying more than one HD stream, so what have I got wrong?! Anyone got any advice please?
On the ReadyNAS I have RAIDiator 5.3.9 and the following Services; SMB NFS, ReadyDLNA, UPnP, HTTP, HTTPS and genie activated. It is setup as X-RAID2 and is fully populated with 2TB WD Reds showing '827.7 GB free of 5.4 TB'.
On the WNDR4500 I have QoS rules giving the ReadyNAS 'Highest' priority.
I had some great support from the Stora forum, so I'm hoping I can finally get to the bottom of my new problems here! Thanks in advance, guys!
Stephen
ProSupport for Business
