aarons1
Sep 14, 2011Aspirant
pro business failing to completely boot (case #16683604)
This morning my Pro Business fell off the network (as it often does, which is totally annoying but a problem for a different thread.) Generally when this happens I press the button on the front twi...
mdgm-ntgr
Sep 14, 2011NETGEAR Employee Retired
I would suggest you open a tech support case (http://www.readynas.com/support). Edit the thread title (i.e. subject of the first post in the thread) to include your case number. The case will need to be escalated to L3, I think.
Unless you are running very old firmware, or are behind a corporate firewall/proxy that blocks it, a secure tunnel connection should be automatically established meaning that there's no need for port forwarding.
