chsu83's avatar
chsu83
Luminary
Dec 27, 2019
Problem - home folders not correct anymore - asking for encryption key
First:
- disabled the X-RAID
- to add a Disk & Create a new second encrypted Volume for a complete backup
- named that volume backup8tb
- more or less "rsync -av /data /backup8tb"
- EXPORTED the backup8tb Volume
Problems I now have - after boot:
- no correctly linked home dirs - are there under /data/home/* but not under /home
+ shares/of homes are created correctly & displayed correctly in frontview
- asking for encryption key at boot - but even when volume / disk is not connected
can anyone help me?
Version 6.9.5 Hotfix 1 (Should be LTS?)
  • if I re-plug the disk with the backup8tb volume
    the messages
    "It is not recommended to mix different disk types. Current volume is using Unknown drives. Please replace the disk in channel 4 (Internal) to match the rest of the disks on volume backup8tb for best performance."
    "Disk in channel 4 (Internal) changed state from RESYNC to ONLINE."
      • StephenB's avatar
        Can you download the log zip file, and copy/paste mdstat.log here?
ProSupport for Business
