Viffergb
Mar 19, 2019Luminary
ReadyNas 102 Volume: System volume root's usage is 86%.
Hi
Over the last few days I have been presented with the following error message in the logs. Can anyone please shed some light on this and what action I need to take in order to rectify it?
- Mar 19, 2019
Welcome to the club!
Reason and solution see here: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/System-volume-root-s-usage-is-xx-This-condition-should-not-occur/m-p/1722477#M178449
Viffergb
Just looked at the s/w manual and the Antivirus button is NOT showing green, so I assume that means it's turned off and therefore my disc root usage should not increase from now on, unless I'm missing something!
Now to go and digest that lengthy solution using 'ssh'. I did spend time yesterday backing up the contents of the NAS to another drive, so if all else fails I could resort to a 'factory reset' and carry out a rebuild, but I'd rather avoid doing that if I can.
asimb
Mar 19, 2019Star
you can find a brief instruction how to do here https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/System-volume-root-s-usage-is-xx-Th... message 3, 7 and 10 (especially jpg-attachment).
